Thread Tools
Old 14-03-2008   #1
Punto Heater Controls
Need some help guys -
Punto 2001 heater controls have packed in - tried changing fuse but no joy
Anything else I could try ?
Thanks in advance
redmel59
redmel59 is offline Reply With Quote Quote
Old 15-03-2008   #2
Re: Punto Heater Controls
Could it be the fan ? behind the glovebox ?
barachello2000 is offline Reply With Quote Quote
Old 15-03-2008   #3
Bravo 1.8 HLX FTW
The Sultan's Avatar
The Sultan has donated!
do you mean the heater itself has stopped blowing air
if so then it will likely be the earth as they are a common fault
500 door handles fit bravo well chuffed
The Sultan is offline Reply With Quote Quote
Old 23-03-2008   #4
Trader Rating: 1
Sorry its not an answer to your question but ianother question...does anyone know how to replace the heater control bulbs on a 95 55s please ? its only the blower direction switch bulb that is out,thanks
kevk is offline Reply With Quote Quote
Old 24-03-2008   #5
vees punto has donated!
Quote Originally Posted by kevk View Post
yes mate,
two allen bolts on the bottom of the heater panel, one behind the middle heater control where when you pull the knob off for the blowers it will have another allen bolt. when removed then you can simply pull the bulb out and place the new one in, be careful as the bulbs are small and delicate. hope this helps you
vees punto is offline Reply With Quote Quote
Old 13-04-2008   #6
Trader Rating: 1
Vees Punto
Sorted!!
Thread Tools
(G) How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto (Mk2/2b) 543 06-06-2008 18:15
