Technical Temperature sensor location
olirip
west wales
Hello my engine light came on, temperature gauge went below the lowest mark and engine fan started up and is on constantly all at the same time , so I'm guessing it's a dodgy temp sensor so I've bought a new one
I just need to locate the sensor, any help would be brilliant
Located temp sensor, remove battery job and get access .
Easy job no need to remove the battery used 19mm spanner and wiggled it through the hosing and wiring looms had enough access to get to sensor
5 mins job
