D Daiton Member Parked in the garage Joined Mar 25, 2016 Messages 114 Points 98 Jan 13, 2018 #1 Hi all,just wondered if any1 has done or something similar to the boost leak fix that is being done on the 500 abarth but on the bravo. Many thanks
A aurick86 Established member Joined Sep 14, 2009 Messages 2,068 Points 461 Location Bucharest Jan 13, 2018 #2 Which boost leak fix? what exactly are you referring to? If you are referring to the evap canister +to intake manifold.... that shouldn't really be a problem...even on the 500 there's a one way valve, that will stop boost going in that line.
OP OP D Daiton Member Parked in the garage Joined Mar 25, 2016 Messages 114 Points 98 Jan 14, 2018 #3 Check it out on youtube,unless I'm just misunderstanding what it is that they are doing
