General  Side repeat lamps goes opposite (need quick answ)
Ronnie
Sweden.
Helvetes jävla kuk!
I have to to the MOT test in 11h 35 min, and now I discovered that my side repeater lamps are strange. If I put the direction indicator to the left the direction lamps in front and rear works as usual (not faster or weaker) BUT the repeater lamps blinks on the right side! (repeater lamp= the orange light on the side of the car)
The exact thing happens when I "blink to the right" but opposite of what I just described.
When I put in the warning lights, the four orange lamps in the corners work fine but BOTH the repeater lamps are dead.
Anyone have a clue what I could do to fix this. Pleae answer as quickly as possible.
Well this occur when the parking light is on. At normal mode the car is almost okey, both side repeater lamp blinks regardless if I want to go R or L. It is 1% chance that they will miss it, otherwise I will say that this is standard behavior on a Uno. Wish me luck, I will need it.
