Radio not switching on...
Do you need help unlocking your radio?
Get your code instantly using our radio unlock service 🔓🎶
A
ACID
had the car fixed...as in head gasket etc.
meaning all cables etc were discnnected
the radio has no code enabled
i went to switch it on., bear in mind no tiem has been set, so its not flashing however it does have the 2 dots to seprate the hours and minutes
afgter switching on, the radio light ups but its still the same display with no time
but nothing else happens??
any ideaS?
havent got a tape to try on
but the grundig cd changer is connecter, the chnager itself is operarting
however on the radio itself you cannot select the changer etc..there is no operation on the radio
checked the fuses..all seem to be ok..i assume the radio fuse wil be titled 'services'?
need to buy official fiat fuses as i have half fiat and the other half universal ones.
mayube the sunlight deceived me
but sorry it doesnt witch on at all
driving at the night the light stays on but the display is blank
any ideas what is wrong
i tried to use the feeder tools but i coudlont pull out the radio...bloody hard to use feeders
any other things i can do?
By the sound of it, the radio gets current to sustain the memory but the real power feed is not working. Check the fuses left of the steering wheel.
Members Site ---------My Site
cheers Sven, ill prob replace them
trouble is the orignal fuses the bravo came with are of a very good quality
recently any motor factors sell a cheap version. the fuses are numbered and not soldered correctly onto the casing, leaving the blade intact lol
i shall also reattempt the feeler gauge tool, as it was struggling to fit yesterday
Hi Sven
fuses seem in place
looking at
http://www.fiatboo.co.uk/run-a-bravo.htm#part8
i dont think it may be the same for all bravos
but the rest of the areas in he car seem to be functioning well
the radio display light coems on, when you press the power button but that its not wording is shown, you can switch off the radio and the display light turns off
i took out the stereo and all connectors which had cables were all in, there is a yellow connector which doesnt have wires..but im only using the standard grunding changer not an aftermarlket system so i assume its meant to be an empty connector
any more ideas?
looks like the door unlock control is in line with the radio
so it canot be the fuse as the door unlock works fine.
weird magically came on when i was driving
has been playign up
with screen freezes and some text missing
sprayed contact cleaner on most parts, change the 10amp radio fuse and a bit better
noticed my aeria is a bitu loose,
its a screw in aerial but now it doesnt screw in, it can be pulled off easily
is that the issue then>
Could be as in some radios the aerial acts as a ground wire.
"Doctor said to give up Keee-Babs. I said 'No, no-no'"
My Members Page
OI! Road safety nutters!! George Orwell ment '1984' to be a warning, NOT a template!
cheers OZ
however odd behaviour
at times on the radio would freeze, meaning no matter how many button pressing does not work..
i can switch it on..and when i switch it off..itll take sometiems 2 minutes to register the OFF button
What i can understand these maybe issue with the radio side as in aerial etc
BUT my cd changer is external expept attached with a lead cable, why is the CD changer acting the same as the radio>?
Does it look liek the stereos gone/
As mentioned i have taken it out and sprayed alot of contact cleaner but to no avail
I
622
IMC63
I
M
6K
mick gibbons
M
F
7K
F1-ANG
F
K
1
329
Dark Lurker
632
David
