Technical  Location of glow plug relay?
MrMultipla
Hello, My bug has the flashing yellow glow-plug light for 20s after startup. FiatECUScan says faulty relay (P0380). Can someone tell me exactly where that relay is please ('02 115 JTD)? I found this guide on Stilo board which says glow-plug relay heater module is attached to the bulkhead so assuming it is similar on Multipla?
Is the flashing yellow light an MOT failure like airbag light because it does go out after a few seconds?
Thanks a lot!
boilermansab - good news, that. It's an expensive relay if I can't get it to work
pistolpete - thanks a lot. There is a doc on there, 'dieselpreheatingfuse.doc' - perfect
Cheers!
Hmm, looks as if the diesel preheating relay is not the same as the glowplugs relay (or is it module?)
With FiatECUScan connected I can activate the 'Glowplug module' test mode and you can hear it click on/off/on/off from inside the car. Seems to be doing something anyway.
Is there a separate error message for glowplugs themselves or could the P0380 Relay/module/ecu error that I'm getting refer to a faulty plug?
Thanks!
