asr button means that you have VDC (stability program) for the car in question. But it doesn't mean there's hill holder too. To check hill holder , get on a hill facing up (more than 5%), brake, put in first gear that release brake. If the car is hold down by brake for 1,5sec, max2 sec means you have hill holder. this 1,5sec allow you to take your time in releasing cluch. Take care : if one of the brake or cluch switch doesn't work well or ECU is under a fault related with these than it will not work.
