If you don't have a curtain airbag it is just a case of pulling the door seal out of the way and gently releasing the 4? clips holding the trim with a flat bladed tool. With curtain airbag there is a bolt to remove as the trim is released. There's no mention of disconnecting battery or disabling airbag system. BETTER DOUBLE CHECK THOUGH
