Dirk_Crisis
- May 30, 2006
- 110
- 20
I'm used to fords. he "min" & "max" levels on all the bits you have to play with under the bonnet are clearly marked and, broadly speaking, they are for the Panda.
However, when checking the oil for the first time yesterday, the levels don't appear to be marked on the stick. The stick itself has a flat end (a bit like an elongated screwdrive head). I'm assuming that if the level hits that head, then it's time for a top up.
Maybe I'm missing something? Maybe I'm over thinking the problem? Maybe there's no real problem at all? I've RTFM'd but I'm none the wiser. Any ideas?
