Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Boot Light Installation<!-- google_ad_section_end -->
How to install a boot light in your Panda, 10 minutes work and 15.
Published by NJP
28-12-2010
Unrated
User Rated:
Difficulty Level: 1
STEP 1 gaining access to the wiring
This shows my light installed in the left hand side of the boot under the parcel shelf. You will have the mounting but no light fitting.
The two cross head screws in the picture need to be removed.
ID:	85050Click image for larger version
ID:	85051Click image for larger version
After the screws are out pull the top of the carpet away from behind the plastic shelf fittings and from the rubber seal around the door frame.
STEP 2 preparing the wiring.
Locate the wire with the white plug from behind the carpet, it will most probably be taped to the bigger bundle of wires, if so remove the tape. Click image for larger version
Pass the plug, the wire and the black plastic clip thorough the prepared (by Fiat) cut in the carpet which is in the form of a cross.
ID:	85054Click image for larger version
ID:	85055Click image for larger version
The last picture shows the plug, wire and clip correctly inserted through the carpet.
STEP 3 inserting the light.
Slide the carpet back into place behind the plastic fittings (the ones from which you took the screws out of). Pass the wire through the light mounting cut out as shown and then connect the light which should illuminate.
ID:	85056Click image for larger version
The light fitting slides up into the mounting and will then snap in at the bottom as shown. The clip that supports the wire pushes, from behind the bracket, into the hole beside the light.
ID:	85058Click image for larger version
ID:	85059Click image for larger version
All that remains to be done is to put the carpet back behind the rubber seal.
The light fitting is Fiat part number 0060665239 and the door switch to turn the light on and off is already installed.
Likes Muddur, steve w hebburn, realsasha liked this post
Old 13-01-2011   #1
South Africa
Re: Boot Light Installation
Tried this today on my Panda - took 10 minutes and works great! Awesome. Thank You.
Thanks Cookecarey thanked for this post
agoolab is offline Reply With Quote Quote
Old 05-05-2011   #2
As above, 10 minutes, didn't even skin my knuckles! Thanks.
Cookecarey is offline Reply With Quote Quote
Old 06-05-2011   #3
Panda on board!
tarbyonline's Avatar
tarbyonline has donated!
added to my "to do" list
Thanks Flipflop12345 thanked for this post
No longer a FIAT owner - i've crossed over to the dark side - 2010 Fiesta Edge 1.25 (60)
My Panda Members Motors thread
Want to change your Panda gear leaver gaiter? See my guide here.
tarbyonline is offline Reply With Quote Quote
Old 05-07-2011   #4
Hi, I have purchased a new boot light for my Euro 5 Panda (2011) but the connecting plug/cables as mentioned in this guide are not live, I'm unable to see any cables at the fuse box of similiar colours, please can anyone advise how to proceed, many thanks in advance.
Graham
Beer Monster is offline Reply With Quote Quote
Old 06-07-2011   #5
Do make sure your car has the appropriate boot latch incorporating microswitch for detecting open/closed condition (probably not so equipped on Euro5) or you will be disappointed (I was!) and will have spent 18 for nowt. Apparently the latch is around 50 from Fiat.
Martin
999auto is offline Reply With Quote Quote
Old 07-07-2011   #6
Thanks for the info regarding the boot latch, I assume the microswitch etc is inside the boot lid as I can't see anything external on any of the doors that operate the front light.
Graham
Old 11-07-2011   #7
Hi BM,
Yes, microswitch is incorporated into the boot latch itself, a short wire harness with connector is attached to it - hence the price I suppose!
Martin
Old 12-07-2011   #8
Hi Martin,
Do you happen to know the part number for said microswitch/loom as I can't find anything listed in ePER Inner Lighting section, thanks.
Graham
Old 05-11-2011   #9
Quote Originally Posted by 999auto View Post
Martin
Thinking out loud here...Would the 'door open' dashboard light be an indicator that you have the appropriate boot latch? For example, with the engine on, all four doors closed and the boot open making a red 'door open' dashboard light appear, can I assume I have the appropriate boot latch incorporating microswitch for detecting open/closed condition?
It would be a simple test before buying the part :)
See my guide How to install an original 12v power socket in a Fiat Panda
2009 Fiat Sedici 1.9 Multijet - Sold Oct 2011
2009 Fiat Panda 1.3 Multijet
50p is offline Reply With Quote Quote
Old 10-11-2011   #10
Took the plunge... and everything works a treat.
I must of had the boot open for so long that when I first connected the light it didn't light up, but closing and re-opening the boot activated the light. Luckily i remembered reading that the boot light times out after a certain lenght of time, so didn't panic!
Old 06-01-2012   #11
Hi thanks for the guide. Can you tell me where I can get the bulb/light unit from?
fugazi9999 is offline Reply With Quote Quote
Old 06-01-2012   #12
Hi fugazi9999
I went into a Fiat dealers and quoted the part number in the guide, they looked confused but tracked it down as it now has a new part number...
The light fitting is Fiat part number 0051878127 and is exactly the same part. I did this upgrade and it worked great.
Good luck, Sean.
Old 20-01-2012   #13
Dazzed & Confused !
gareth111278's Avatar
gareth111278 has donated!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=390323093683
Found this on Flea-Bay, is it the right one?
Not much, if any cheaper than the 18 quoted above, but better if you're miles from a dealer!
Gareth
gareth111278 is offline Reply With Quote Quote
Old 21-01-2012   #14
Quote Originally Posted by gareth111278 View Post
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390323093683
By the looks of it I would say yes.
Thanks gareth111278 thanked for this post
Likes Muddur liked this post
Comment
Search this Guide:
(T) Interior Light and Boot Light Problem - Please Help sballard4 Punto (Mk2/2b) 7 01-06-2009 13:17
(G) glove box light and boot light dreamworx Stilo 0 20-01-2008 18:43
(G) Punto 55S internal reading light & boot light not working - fuse? dvdfever Punto (Mk1) 7 20-02-2007 01:08
Aftermarket cd changer in boot installation badkilla I.C.E 1 01-12-2006 21:52
