Hi all, bit of a strange one, but at what angle does the windscreen in a mk2 panda sit? I want to work something out...
As of the weekend yours could be any angle almost inverted !!!
Of course the top defiantly was lower than the front edge don't know what was happening to the oil ha
Oh no. Didn't even think of that!!
Did you have a rush of blood to the head and then got pins and needles in your toes !! [emoji209]?
I have it 42 degrees acute
So over 48 degrees to make screen wash run towards windscreen 'top'.
Ok we now need the rate of flow
I.e. How quickly the water moved across the screen and then the drag coefficient from a-b based upon the droplet size .also did any pooling occur but don't forget which clock angled it also moved. There that should do it
