Hi all,
New track control arm now fitted - relatively easy job - no probs if the balljoint isn't troublesome!
Got the new lower engine transmission mounting (pad) at last but 'Sikaflex' repair of the old one is still okay and I'm interested to see how long that will last...
Tank strap is knacked - may be secure enough for MOT - not sure on this one as the front strap has gone completely (seen other Panda's with this hanging down!) - thing is the front mounting bolt is up behind the Omega axle mounting bracket. Does this need to be dropped to get to that bolt? Has anyone got to it without dropping the mounting? Looks a bit tight to me. All other bolts are free. Any suggestions for replacing the tank strap?
cheers all,
only two weeks to dreaded MOT now...
(the rear brake compensator valve has gone on the Ducato as well just to add to my seasonal enjoyment!)
cheers all,
