sabeltandcavia
I've read on some other Forum that it is impossible to fit 15 inch wheels, without major modifications to the car. And that if you'd try to mount 15 inch wheels on a regular Panda, they would hit the fenders, but I think 15 inch wheels CAN be fit without much of a problem.
Here's the normal situation:
135/70 R13 so the height of the tire is 70% of 135mm= 94.5mm. A 13 inch wheel is 33.02 centimeter high, so the total height of the wheel is (2x9.45cm)+33.02cm=51,92cm
With 15 inch wheels (and low-profile tires!)
195/45 VR15 so here the height of the tire is 45% of 195mm=87.75mm. 15 inch wheels are 38.1cm high, so the wheel is a total of (2x8.775)+38.1=55.56cm
So the difference in diameter is only 55.56-51.92=3.64cm, so the radius of the wheel would only change half of that, 1.82cm. There's plenty of room on either side of the tire to make 'm 1.8 cm bigger (on either side).
So the old wheels were 5x13 inch with an ET of 27mm. 5 inch is 12.7cm, so space from the hub to the inner edge of the wheel is 6.35+0.27=6.62cm
The new wheels would be 7x15, ET will be the same. 7 inch is 17.78cm, so half of that + the ET value = 9.16cm from the hub to the inner edge of the wheel.
The difference is 9.16-6.62=2.54cm (exactly 1 inch) I'm not sure about this, but it seems to me it wouldn't be much of a problem if a wheel was pointed inwards 2 and a half centimeter more.
Am I missing something here, or is this right?
JvE
~~Nulla Tenaci Invia est Via~~
JvE
