did you set the timing at no 1 plug first with the timing marks lined up? if not,set the engine to this.it is either right after this or 180 degrees out[that is one revolution].this does not matter.all it will do is fire off no 4 plug.if you have set the timing at no 1 and it does not fire,then swap the HT LEADS OVER or reset the dizzy at no 4.hope this is clear for you.a common problem ive seen dozens of time. good luck.any problems let me know.i will try to guide you through.
