Hi Guys
Could you help with an Auto Gearbox issue.
Our Rav4 Auto gearbox has been playing up since last week, clunking when Reverse is engaged and then jumping or having problems with 2nd gear and also loosing power.
Its 2002 petrol model – Rav4 VVTi.
I looked up and the issue seemed to be with the ECU, as a test I disconnected the negative terminal for 5 mins, the car was fine after this even the O2 sensnor light (engine light) had gone, after parking the car and driving again same problem with gearbox but engine light had come back before parking.
I took the car into an Auto specialist who diagnosed with code P0755 – shift solenoid B, see this; http://engine-codes.com/p0755.html
Since a proper reset has been done the car drives well (O2 light is back), I will test again today.
If the issue is still there I think I need to do the following; check gearbox oil level, remove and clean gearbox sump and change oil, check Solenoid !! change the dreaded ECU.
Another question ?
Will buying an OBDII reader allow me to reset the ECU at will, are they easy to use ?
If any OBDII experts out there and if you have time could you recommend an OBDII reader from ebay with the right cable, this link may help http://www.toyotaownersclub.com/foru...owtopic=130059
Ultimately I am trying to buy time with the RAV as its still a good workhorse.
Thanks again
Another question ?
Thanks again
