Thread Tools
Old 29-03-2019   #1
South Africa
Fiat Uno 1100 Car Jerks And Fire Up When Accelerates
Yesterday night I parked my car very nicely after work, just this morning when I start it to warm up I noticed the unusual idling of the car and it was firing up at the exhaust., I thought maybe it will come up right as soon as the engine starts to heat up I got in and drove to work, when I accelerates the car stutter and it's firing so bad at the back but I managed to get to work. The weather is so cold here and the car is parked on the grass where it's wet and cold. What could be the cause of the problem?
tumi1986 is offline Reply With Quote Quote
Old 29-03-2019   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Fiat Uno 1100 Car Jerks And Fire Up When Accelerates
Quote Originally Posted by tumi1986 View Post
When its dark, open the bonnet and fire it up. See if there are any sparks from the coils, leads, plugs area that are visible.
D
Likes tumi1986 liked this post
Old 29-03-2019   #3
South Africa
Thanks I did that just now, there was a plug that was not burning right seems like it wa split by the oil changed it and everything is fine. I don't know if the cause was the tension lid to the plug but I'll check until weekend then I'll replace the lid.
Likes rallycinq liked this post
Old 01-04-2019   #4
South Africa
Good morning after changing the spark plug on Friday the car was fine and stdy it started again I went to town and got a carb cleaner we cleaned with the mech and it was fine again, yesterday it all started again this time no firing up but it would run smooth then all of a sudden starts to vibrate and idle as if it's strangeled I don't know whereelse to look now please advice
Old 01-04-2019   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
When its vibrating, remove and replace one plug lead at a time. Use insulated pliers unless you like breakdancing.
Find the one or two that makes no difference to the vibration when removed.
D
Old 02-04-2019   #6
South Africa
Okay thanks it's been ruining smooth for 2days now the moment it's start again I will try that
Thread Tools
(G) fiat uno 1100 fire jazeed Uno 0 09-10-2014 19:04
(G) fiat uno fire 1100 petrol pump stash Uno 0 08-02-2004 13:55
