Old 06-01-2015   #1
Immobilizer transponder problem
Hi everyone and Happy New Year.
First time to post a message...novice.
I have a fiat panda 2007 1.2 petrol 4x4 that out of the blue fails to start and the yellow light with a padlock lights up and stays when the key is turned on. I found out that Fiat has an emergency starting procedure so I been doing it every day to go to work and back (a bit of a pain). I have plugged the diagnostic equipment and it comes up with fault-u1600 no key communication.
This happened about a month ago and after a week or so the car started to start quite some times with the key, it seemed it was learning the transponder code again but to my annoyance for the past week I can not get it started again without the emergency procedure.
I have only one key, blue with remote control.
I have replaced the transponder areal on the key barrel to no avail.
the battery is fine.?
will a second hand bsi and key work with the original ecu?
Any advise appreciated.
any other suggestion?
many thanks
Los
los34 is offline Reply With Quote Quote
(T) Stilo Key Coding and Transponder problem Dave Evans Stilo 4 06-05-2013 19:38
(T) Immobilizer problem fjasa Punto (Mk2/2b) 3 14-10-2007 14:14
(T) Immobilizer Problem ctrl_rst Punto (Mk2/2b) 8 26-03-2007 16:10
(T) Help! Immobilizer problem after battery change bravatwozero Bravo / Brava 26 01-11-2006 09:46
(G) problem on my immobilizer srazcom Ulysse 9 18-07-2005 20:13
