blade2108 New member Parked in the garage Joined Jan 10, 2008 Messages 71 Points 29 Location Liverpool Mar 22, 2009 #1 anyone know a good place to get a db rating on my install in merseyside/north west? thanks.
volxstu More ICE Please Parked in the garage Joined Jan 9, 2007 Messages 13,898 Points 2,309 Location Kent Mar 22, 2009 #2 You need a speclab and they are pretty few and far between TBH.
volxstu More ICE Please Parked in the garage Joined Jan 9, 2007 Messages 13,898 Points 2,309 Location Kent Mar 22, 2009 #3 I would say around 125db
OP OP blade2108 New member Parked in the garage Joined Jan 10, 2008 Messages 71 Points 29 Location Liverpool Mar 22, 2009 #4 sound, thnks mate. how much of a difference do you think it will make when i put the front comps in?
volxstu More ICE Please Parked in the garage Joined Jan 9, 2007 Messages 13,898 Points 2,309 Location Kent Mar 22, 2009 #5 Nothing to overall DB really because its is the subs that are the loudest, hence the furthest away. Try searching the net for decent audio dealers where you are, I believe Source and Phattbeats are somewhere near you they may have a speclab.
OP OP blade2108 New member Parked in the garage Joined Jan 10, 2008 Messages 71 Points 29 Location Liverpool Mar 22, 2009 #6 il phone em tmz lol was also thinking of uprating the battery as well is it worth it with this sizw of install??
volxstu More ICE Please Parked in the garage Joined Jan 9, 2007 Messages 13,898 Points 2,309 Location Kent Mar 23, 2009 #7 Not really worth doing the batt until you are running over 1500w RMS. I would suggest doing TB3 though.
OP OP blade2108 New member Parked in the garage Joined Jan 10, 2008 Messages 71 Points 29 Location Liverpool Mar 25, 2009 #8 i may sound stupid but wat? lol
paulbfd Patron member Parked in the garage Written a guide Joined Apr 28, 2005 Messages 3,262 Points 599 Location West Yorkshire Mar 25, 2009 #9 Upgrade your battery earth, alternator to battery and (if fitted) alternator earth cables to 4awg minimum. Thicker cable means less voltage drop therefore more power! I got nearly a 1 volt from just putting on a thicker battery earth. And try Mega Watt in Runcorn for your dB testing.
volxstu More ICE Please Parked in the garage Joined Jan 9, 2007 Messages 13,898 Points 2,309 Location Kent Mar 25, 2009 #10 Upgrade the big three. -ve battery to chassis +ve altenator to +ve battery -ve engine to chassis
