Prep work
Now that you have your mirrors off and the glass out its time to start marking out where you need the holes.
Roughly find the center of the mirror and mark the center of the circular end with a pencil.
Run a strip of masking tape along the edge of the style line keeping it tight and line it up with the pencil mark.
Check how it looks, if its not good enough just lift it and edge it up or down until it looks okay.
Make a mark about 10mm in from the edge of the mirror, this will be where you want your lightstrip to start.
Measure the distance between LED's on the strip, in my case they where 17mm apart.
Use another strip of masking tape, lay it out flat on a clean surface and use a steel rule to make a mark every 17mm. Make sure your pencil is sharp, as a blut mark may throw the next one off by 1mm, then by the time your at the last one your off by 5mm!
Lift the strip off the surface and transfer it to the mirror, lining up the 1st mark with the mark on the masking tape on mirror.
