Hi i made a diy anti Mouse inhalation gril in the air intake tube bend.
It is really simple to install:
  • removed the bend behind the air intake bar under the hood.
  • used a mesh gril RVS 6 mm Square and cut it a little bit bigger than the inside diameter
  • used a soldering pistol to melt the mesh into the plastic bend.
This modification was made due to a Mouse in my airfillter discovered while changing the filters 🤨
