After getting new tyres fitted on my fiat punto (2006), and the allignment checked and adjusted a fault plays up. The speedo stops working after having driven a few miles and several warning lights pop up (esp, pas, engine warning and some others). I have checked for faults using the OBD port and cleared all codes, but the P0500 indicating a faulty vehicle speed sensor 'A' reappears.
having sensors on all 4 wheels i assume it has ABS.
I came across some threads with similar issues, but they all concerned non ABS cars, where the VSS is in the gearbox, but a ABS car uses the sensors on the 4 corners. Is there any way I can check which one gives trouble? Issue is that the problem only appears after some driving, and not immidiately, and from the error code I can't see a specific sensor that gives trouble.
many thanks for the advise.
