As soon as the rails/guides are the same they'll fit and you will gain the benefit of tilting the passenger seat if ever you need to put long object in the car ...
Regarding the airbag, disconnect the battery (negative first) before attempting ANYTHING on them and use a grounding whrist for static discharge.
Seats may have different trim options: lombar adjustement, heater, that might not be supported in your car; with a bit of skill you'd be able to activate them !
BRs, Bernie
