Technical Clutch pedal sensor
korithi
I have a grande punto 2008 1.4 8v petrol.
Can anyone tell me the part number for the of the clutch sensor located under the pedal?
A part of it is tightened to the pedal and moves along with the pedal.
What is its purpose and what symptoms it causes if it dpes not work properly?
Hello guys,
I also took the car to mechanic, and check the real values of clutch switch, but it always says it is closed. Even when I press the pedal nothing changes.
Can anyone please help?
Well If you have cruise control that will probably refuse to engage due to an error being stored.
I know that for the punto evo diesel, the throttle would behave differently for fully pressed, partially pressed and not pressed at all. When I unplugged my sensor This resulted in the car bogging a bit and being hard to control when driving off from a standstill.
