- Jan 6, 2007
- 21
- 8
Hi everyone, first time posting on the punto section but thought this might be of some interest to someone. I've been working on cars as an for a good few years out of necessity rather than desire and have done head gaskets, gearboxes and quite a few cambelts etc over the years. Being a nice guy I offered to help a friend out and change her cambelt on a 1.2 8v. I read up and was happy to here even if you time up the car wrong the valves cant touch the pistons and once you retime it everything will be fine. I would usually mark up the crank and cam and the old belt whilst fitted then mark the new belt and simply swap over, however this time I took off the central bolt in the crank pulley by mistake and low-and-behold the cambelt was off and nothing was timed. Never mind, I timed up to what I thought where the timing marks and figured I'd give it a go by hand and see what happened. remembering that i couldn't do any damage to the valves even if I got it wrong.
This is where it gets messy.
It took a lot of effort to turn the engine over by hand, I now know this is because I had to put enough effort in to bend each of the exhaust valves in turn. It turns over lovely and freely on the key because I have absolutely no compression in any cylinder now. I don't know how to put photo's on here but if someone can explain I will put up pics of how bent the valves are.
The state of play now.
Currently have a friends car in pieces on my drive awaiting delivery of some new valves, feeling terrible for making an easy job into a week long slog and costing consideribly more than it should. Wife is not speaking to me as have spent two days so far working on car and ignoring her. Only saving grace it that mate is very understanding and hopefully once new head gasket valves etc are fitted the parts bill will be less than a cambelt change would have cost a garage anyway.
Lessons learnt.
1. when putting on cambelt make 100% sure timing marks are correct.
2. don't believe everything you read.
3. valves are really hard to get hold of, especially in a hurry.
4. working on friends cars is consideribly more stressful than working on your own.
Lessons learnt.
