General Dualogic "Gear not available" in reverse
LemonBear
Just got a 1.4 GP with dualogic gearbox (32k miles). If I reverse out of my drive the car gets stuck in reverse bleeping gear not available once I return it to neutral and try to engage first/auto. If I turn off an on again then it bleeps for a little bit then engages first gear.
It only does this from a cold start, I wonder if its dualogic gearbox oil pressure? I've got no other warnings but its definitely getting worse :(
did you get this problem fixed? i'm having the same issue
I don't recall the detail, it was main dealer replaced - the cost was mostly the part (I think 800 of it) but then there was labour.
I have the bill around here if it might be of help to ame.
Given I'd had no problem with a dualogic panda, it was quite a shock to the finance.
Hello Lemon
Can you tell me part reference,I like cold start problem
