Any ideas of real experience nature sought as it is a new car to us and the jury is still out although her mechanic seems to hate them, says they are too complicated in the electrical side and badly built.
1. mechanic changes cam belt
2. car runs smooth (he says)
3. after 1 mile, the engine management light comes on a couple of times and now the engine hunts around 500 to 1200 rpm at idle and she says it runs away from her when in lower gears in traffic whereas it was running dead steady before.
seems the behaviour of an engine that is a tad too advanced to me.
Is it
the belt tension?
missing part from cam belt adjuster ?
has the mechanic damaged the cam position sensor or VVT pulley ?
how far out can the timing be, this seems to me a timing or ECU based fault?
Unless one of his several hangers on or dodgy helper poked a hole in a hose or did damage themselves. He is pointing at the throttle body and saying it likely has a leak!
Let's assume the mechanic means well and has just forgotten to tighten the pulley or fitted it wrong as the car accelerates well enough, seems to me the timing is not out by much, but the belt? how badly would it have to be tensioned?
have not been out on the open road to truly tell if performance is down after a distance or the engine is overheating cutting out at speed or is running too cool
Is it
the belt tension?
