Old 18-10-2009   #1
.:Schalke 04:.
boddahchris has donated!
Ciggy lighter in the glove compartment.
I'm running my usb hard drive to my b&m which is great cause it holds all of my music, however the b&m doesn't supply the drive with enough power so i run another wire to the ciggy lighter via a converter but it is very messy with the wires everywhere.
I want to install another ciggy lighter socket in the glove compartment to keep it all tucked out of sight.
anyone know how i go about this?
boddahchris is offline Reply With Quote Quote
Old 18-10-2009   #2
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Ciggy lighter in the glove compartment.
Quote Originally Posted by boddahchris View Post
get one of these
http://www.maplin.co.uk/module.aspx?...te%20Extension
cut the plug off
drop the side panel off in the passenger foot well (see my Pollen filter guide)
draw the wire down the back of the glove box...
pop the gear gaitor off
pull wire through to there
tap into live and earth on fag lighter socket solder or scotch hooks (put a inline fuse holder in the live ((center tip of the holder))
Thanks boddahchris thanked for this post
Massive gash
Just a little touch up
Old 18-10-2009   #3
.:Schalke 04:.
Quote Originally Posted by Andy Monty View Post
get one of these
cut the plug off
Thats just what i needed! cheers!
Just a couple more Q's
Whats a scotch hook?
How do i know which is earth and live both on the new wire and the one i'm tapping into?
Old 18-10-2009   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
think he ment 'scotch-lock', (a rather crude connector for splicing into a original wire)
Old 18-10-2009   #5
Quote Originally Posted by T14086 View Post
Not as crude as twist wire and add leccy tape.....
of course I've never done such a thing
Black TJet -
http://s7.photobucket.com/albums/y280/dpr59/Cars/
dpr59 is offline Reply With Quote Quote
Old 18-10-2009   #6
Moderator
Andy Monty's Avatar
thats the one
Massive gash
Old 18-10-2009   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by dpr59 View Post
tut tut...solder & heatshrink always the best wat.
Old 18-10-2009   #8
Moderator
Andy Monty's Avatar
darn that T key getting in the way of Y
problem with heat shrink is you have to cut the original wire to get it on
solder and self amalgamating tape TWF (but it comes at a price)
http://www.maplin.co.uk/Module.aspx?ModuleNo=4099
Massive gash
Old 18-10-2009   #9
make sure you get some pics up when ur finished!
steve119 is offline Reply With Quote Quote
Old 18-10-2009   #10
.:Schalke 04:.
Ok cheers guys, think i'm gonna go with the solder and heat shrink.
I'm guessing i just solder the two ciggy lines straight to the one from the car. in a sort of Y shape?
Old 18-10-2009   #11
Moderator
Andy Monty's Avatar
yep thats what you want to do
the wires you want are red and black (live and earth respectively) the yellow thin wire is the illumination for the glow ring ((if fitted))
you will find it easyer to unplug it from the back of the lighter to get a bit more length to work on
Massive gash
(G) Glove Compartment Aantje Panda 0 28-02-2009 22:42
(G) permanent ciggy lighter live Alfa The Awesome Stilo 11 29-01-2008 21:54
(G) Random ciggy lighter question netrix Uno 3 09-05-2007 12:11
(G) Glove Compartment platty599 Stilo 4 26-10-2006 17:57
(G) help wiring a ciggy lighter. christopher watson Panda (Classic) 45 01-10-2005 15:42
