I Fitted the original Fiat iPOD connection Kit to my 1.2 GP Dynamic, and it was quite easy once I worked out that you need Pins from Halfords to remove it.
My Kit cost me £85 in total and came from Italia (Italy) maybe I was robed I don't know but dealer wanted £350 to fit!!!!!!
Officially you cant navigate through the iPOD once its connected, but if you start the car get the ipod playing then disconnect it without switching of the radio and re-connect it then you can navigate through.
Fiat suggest you feed the cable down through the center console to the back of the cup holders in-front of the Shift Stick. Took me 5 minutes.
I think yours is the same and cheaper, so go for it, Its really easy to install, the plug only fits in one place anyway.
Hope this helps,
EDIT*** I JUST READ THE LISTING, IT SAYS
Please note - this interface is not compatible with 'factory fitted' Blaupunkt head-units. To check compatibilty with your head unit please see this compatibilty list. If you are unsure at all about the suitability of this item please email us at [email protected] with the model of your head unit and we will provide a rapid response. A handling charge will be levied against any returns of this item.
I would look at this one:
http://cgi.ebay.co.uk/FIAT-GRANDE-PUNTO-IPOD-KIT-ALL-MODELS_W0QQitemZ180170570923QQihZ008QQcategoryZ10382QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jason
