Comment
Guide Tools
<!-- google_ad_section_start -->Fitting a vacuum Boost Gauge to a M-Jet & T-Jet<!-- google_ad_section_end -->
Published by Reuuk
14-09-2013
Difficulty Level: 2
User Rated:Unrated
Okay firstly we want to get all the thing we will need to fit a boost Gauge on our Mjet & Tjet (see below).
things you will need!
Boost Gauge
Silcone Vacuum hose ( I used 3mm ID)
Gauge holder (Pod)
Zip Ties
something to tap into the Inlet pipe eg; Brake bleed nipple
'Anti buzz restricters' aka Vacuum hose connectors.
lets move on.....
okay so we have all the items we need to complete our Boost Gauge installation
step one;
Remove engine cover
step two;
Locate the Air inlet pipe
Name:	AIR INLET.jpg
step 4
Depending what your using to tap into your inlet pipe will depend on what size hole you need to drill. I drilled into the 'bigger' raised section of the inlet pipe to give abit more 'bite' on securing the vacuum inlet.
step 5
If you have a thread tap to hand, go ahead a tap a thread into the hole and inset your 'nipple' (if you don't have a thread tap I'm sure abit of epoxy resin mixxed up would be okay.. CHECK FOR LEAKS THOUGH!)
step 6
next you want to feed your vacuum hose through the bulkhead, I used the same passing as the 'bonnet release cable' this is under the cover where your windscreen mechs sit.
Name:	BULK HEAD GROM.jpg
it helps to have two people here, one to feed the hose and one lying on their back in the footwell with there hand up the back of the dash ready to grab the cable and pull it through for you, once this is done go ahead and route your vacuum hose where you want the gauge to be. MAKE SURE YOUR HOSE DOES NOT HAVE ANY KINKS OR ROUTED SOMEWHERE IT WILL SNAG ON SOMETHING SHARP!
step 7
decide where you want to mount your gauge,
I personally mounted the gauge on the A pillar with self tapping screws.
step 8
once you've fed the cable through get your power and earth cables from the box of your gauge..
Red = live
black = negative
go ahead a solder these to your cigarette lighter/dash live and earth.
step 9
now back to the engine bay.
go ahead and attach your vacuum to your 'vacuum inlet tap'
I used a small zip tie to secure the hose on.
step 10
attach the other end of the hose to your gauge, turn your car on and test for any escaping air from the tap.
now if your installing this on a diesel you may find you have allot of 'vibration/buzz' on your gauge. not to worrie! just cut your vacuum hose approx 8-10 inches from the inlet pipe and install one of your hose 'anti buzz connectors' (vacuum hose connector)
I needed to install two to stop the vibration on my gauge. so I placed another 6-8inchs down the vacuum hose from the Gauge
if all is okay, go ahead and tighten everything up ( like your boost gauge mount)
Sit back and enjoy
Okay so I listed this as difficulty level 2. thats my personal review on how 'hard' this instalation was. If your abit iffy about taking a drill to your car then I'd say just take your time
T-JET ENGINES
For T-jet Engines all you need to do is T-piece off your boost vacuum, this is at the top right of your engine under the engine cover, the wiring and feed of Vacuum is all the same as above
Picture courtesy of Dlightswitch.
Old 14-09-2013   #1
T-Jet!
Sweex's Avatar
Sweex has donated!
Re: 1.9 Mjet vacuum Boost Gauge Installation
I like that you've gone for an orange hose! Looks good
Is it this easy on my t-jet?
My Grande Punto T-Jet Daisy
Sweex is offline Reply With Quote Quote
Old 14-09-2013   #2
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk is part of the official FF Events Team :)
Reuuk has donated!
Babe Jump Champion, Sofa Longjump Champion, Space Explorer Champion
@Sweex I imagine so, I've never really had a good look around a Tjet's engine.. but I can't imagine it would be much different! with you being able to have a pressure release valve on a tjet I imagine you can just connect it to the lines that are already in place..without having to drill
follow me on Instagram: @reuuk
Mini Cooper S & Abarth 500
Reuuk is offline Reply With Quote Quote
Old 14-09-2013   #3
T-Jet!
Sweex's Avatar
Sweex has donated!
I could just T piece it off then i reckon
Old 14-09-2013   #4
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk has donated!
Quote Originally Posted by Sweex View Post
yup
Likes Sweex liked this post
Old 14-09-2013   #5
T-Jet!
Sweex's Avatar
Sweex has donated!
Quote Originally Posted by Reuuk View Post
yup
You are a torx piece (star)
Likes Reuuk liked this post
Old 14-09-2013   #6
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk has donated!
@JackFi would be able to help with the tjet questions as I know he has one
Old 14-09-2013   #7
ElliottMK2B has donated!
How did you route the vacuum hose from the passenger side to where you've positioned the gauge on the driver's side? Behind the dash?
Grande Punto Sporting T-Jet.
My Member's Motors thread!
ElliottMK2B is offline Reply With Quote Quote
Old 14-09-2013   #8
Anti-lag ftw!
Reuuk's Avatar
Trader Rating: 1
Reuuk has donated!
Quote Originally Posted by ElliottMK2B View Post
yes just simply fed it towards center console and up under steering collum
Thanks ElliottMK2B thanked for this post
Old 15-10-2013   #9
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Baghdad Bowling Champion
Finland
Sorry first time Ive been on FF on my laptop & realised I was mentioned in this thread, all tjet boost gauge questions fire my way
Thanks Sweex thanked for this post
JOIN US! Just search "BRAVO ENTHUSIASTS" ON FACEBOOK!
JackFi is offline Reply With Quote Quote
Old 15-10-2013   #10
T-Jet!
Sweex's Avatar
Sweex has donated!
Quote Originally Posted by JackFi View Post
Where do you take the vaccum off?
Old 16-10-2013   #11
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Finland
Hey dude, I will get a pic of it in the next couple of days, there is a thread on here with where to put the t piece. I will try and find it now.
Old 16-10-2013   #12
T-Jet!
Sweex's Avatar
Sweex has donated!
Do you T off the boost pressure vaccumm?
Old 16-10-2013   #13
F*** Its A Turbo
JackFi's Avatar
Trader Rating: 1
JackFi has donated!
Finland
Yeah mate
Old 16-10-2013   #14
T-Jet!
Sweex's Avatar
Sweex has donated!
Thought so bud!
Likes Aidenw1 liked this post
Comment
Guide Tools
(Tu) Fitting Boost Gauge On T-Jet seaneb2003 Grande Punto 10 01-10-2013 16:00
(G) 1.4 T-Jet boost gauge AndyH Bravo 18 01-12-2009 17:10
(T) boost gauge for t-jet bajandrifter Grande Punto 16 07-10-2009 12:01
(T) Anyone installed a Boost Gauge on their T-Jet oneoneeight Grande Punto 1 21-10-2007 11:50
