callumt said:I think you can buy one that means you take the shocker bolt out then put the arb in place and put the bolt back in. No need for drilling. Where is it your getting it from ?
Try potn.com
scoop_987 said:Somehow I don't think that my punto is going to have the same rear cross member as your cinq.
I'll see my boss as to what he thinks I should use but I've got a feeling that carbon spring steel would need to be used.
callumt said:
this is what i mean. this ANTI ROLL BAR doesnt actually bolt onto the chassis. it only bolts onto the 2 shockers and its held onto the rear beam as you can see by a big jubilee clip and 2 bushes. a brace goes inside the car not underneath.
i made it out like i meant it just went from shocker to shocker with nothing in between so thats my bad ! i actually meant this
anyway i hope this pic helps because this is the set-up that it will most likely be if you buy one
gengis said:I would have though that if you make your car stiffer at the rear, it would induce understeer at the front?
