shaking bravo + + +
shaking bravo + + +
T
tina
Guest
bravo 1997 new shocks, arms drive shafts replaced new clutch, balanced wheels still shakes at 40mph + any other ideas
please
maybe u wheel is buckeled??
check ur brakes, make sure ur wheel nuts are tight.
Its a 1.4 Chassis, 1.6 Engine and 2.0ltr Brakes and half a Marea :)
Follow My Project
Updated: 06/07/2008
did hit curb quite hard other day run off rd have changed front wheels and there is still shaking not as bad as before but still there ???
u might have damage some internal parts. was is from that day it started shaking?
Follow My Project
Updated: 06/07/2008
yea pretty much someone has said it may be the ?shaft in gear box (sorry not mechanically minded) they also said that would prob be new gearbox !!!!
Did you hit a kerb after fitting all those new parts?
You might have damaged your bottom arm/wishbone watever you wanna call it!
no before thats why i had parts changed on advise of ?garage
Read the other 'shaking' threads for ideas.
If your running aftermarket wheels im going to put my money on incorrect sized spigot rings.
If it wasn't shaking before hitting the kurb, take the car back to the garage and tell them to sort it out!
Similar threads
M
Replies
Views
7K
M
A
Replies
1
Views
11K
Angelo
A
I
Replies
Views
807
IMC63
I
I
Replies
1
Views
6K
stevew
S
