S
Si
Guest
6x9's
Can't quite remember the size of the standard speakers, think their 5x7's in the front doors, i'll check tonight.
You'll have to make up an MDF ring to mount the 6x9's into to give you enough space if you don't want to take a metal cutter to your door to make the standard hole bigger.
You also need to be careful of getting the door card back on again, so you'll also need to check theres space inside that to fit a 6x9.
As for the high pass filter, the Fiat one is awuful, it's set to work with standard speakers not uprated ones.
You don't want much bass up front, that's what the sub will be there for. Speakers are there to play mid and treble, if you want bass get a sub.
