im Axle Specialists
Old 06-04-2019   #1
Romania
Fiat croma 1.9 150 hp. Asr unavailable,abs unavailable Pls help me
I have on dashboard brake pads light and triangle with ! yellow both.When i connect Elm 327 interface, on Abs system and press Y(for yes) on display say Asr unavailable, Abs unavailable and a beep sound. Why cannot connect? At engine i can connect. At other car i can connect to Abs. Please help me
P.S sorry for my bad English
22tony is offline Reply With Quote Quote
Old 06-04-2019   #2
Re: Fiat croma 1.9 150 hp. Asr unavailable,abs unavailable Pls help me
Hi Tony,
Thought I'd posted a reply to you but it seems to have vanished
First thing is whether you have had any other random faults recently. A failing battery can generate all manner of odd faults and failures that don't seem to be battery related. Try giving it a good charge or get it tested if it's old or hasn't been used much for a while.
Next thing is to check the cables and connectors inside the wheel arch are corroded or even work through. You should be able to check without taking the wheels off but it's easier if you do.
BrianMcL is offline Reply With Quote Quote
Old 07-04-2019   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Quote Originally Posted by 22tony View Post
Sorry for slow reponse I'm away from home on business.
To connect to the ABS sytem on a Croma you need a A1 "Green" adaptor lea between the ELM327 and the car. A set of 3 is
http://www.ebay.co.uk/itm/Fiat-Alfa-.../281385011211?
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Old 07-04-2019   #4
Romania
I know how to connect to engine,abs,airbag.i have adapters (connectors)
Old 09-04-2019   #5
Moderator
g8rpi's Avatar
g8rpi has donated!
Have you done basics like checking fuses and connectors? Read fault codes and done a Proxy-alignment?
It sounds lie the ABS node is not on the CAN bus. this coul be lack of power, bad connection, short circuit in wiring or faulty ECU. Has anything appened to the car recently? ny other fauls or problems? Did te fault just appear?
Robert G8RPI.
(T) ABS, ASR (TC) ESP & Hill Hold Assist Unavailable NickFontana14 Grande Punto 7 22-12-2017 08:10
(T) ABS Unavailable! Totos owner Grande Punto 3 29-05-2014 09:40
(G) ESP/ASR/Hillhold unavailable Pomp Bravo 31 18-08-2012 17:55
(T) ABS unavailable? mikey mikey mikey Bravo 3 24-06-2009 21:43
(T) ABS Unavailable Sexyeyes83 Grande Punto 21 31-12-2007 17:04
