Well, I've bought a Croma.
A few things to sort, but one that is particularly bothering me.
I've got the dreaded skydome.
It jammed open on a previous owner and was closed and 'disabled' by Fiat.
Problem is, they left the blinds open.
The rear one is easy, clip is broken, I can sort that.
But the front is more of an issue.
I've checked the fuses, they're present, so they must have either disconnected the motor or disabled it in software (assuming that's possible).
I've tried 'moderate force', but it won't budge.
Are the plug connections under the rear headlining?
Is there any way I can check in MES to see if it's been disabled electronically?
There's not as much hair up top as there used to be and I'm having to wear a hat on sunny days!
