Thread Tools
Old 23-01-2019   #1
Slovakia
Question ASR off
Hello friends, few days ago on the highway, it was a heavy snow/rainy day my Croma suddenly announced me ASR failure
ASR failure = ASR off = tachometer down /not showing me my actual speed/ = automatic locking door isnt automatic /only manually/ not showing me info about distance, fuel consumption on display... what do you think it might be?
Diagnosis not showing me info about asr failure....
Sometimes when i start car, everything seems to be allright, automatic lock door working, tachometer working and after few metres , ASR failure again, tacho down, every infos out...
I have also ESP, ABS, Hill Holder failures but i know about it, rear and front right wheels not communicating (abs sensor) - working on it........but on diagnosis i dont see anything with should be with ASR...
If is here somebody who can help me, i will be grateful
Anapolon11 is offline Reply With Quote Quote
Old 24-01-2019   #2
s130 has donated!
Re: ASR off
I would start by checking all main battery connections and chassis -ve cable. Then check / test the battery and finally test the alternator.
If the main electrics are not up to par then all sorts of errors can be thrown.
s130 is offline Reply With Quote Quote
Old 25-01-2019   #3
Moderator
g8rpi's Avatar
g8rpi has donated!
Re: ASR off
What diagnostics are you using? Are there any error codes?
It sounds like a bad connection somewhere. Have a good look around including checking the fuses and connections in the battery connecton box.
Robert G8RPI.
g8rpi is offline Reply With Quote Quote
Thread Tools
(T) ASR issue... hisXLNC Punto (Mk2/2b) 2 09-08-2015 15:56
Asr br4duk Tech Talk 0 27-04-2015 22:07
(T) Asr NightWolf65 Stilo 5 08-04-2013 23:31
(T) Asr tim1989 Punto (Mk2/2b) 3 02-11-2008 10:12
(G) ASR off Alex_gregory_uk Grande Punto 6 04-11-2006 07:19
