Watch the weights, I think u will be over the 1.5t max. A twin axle car transporter weights about 550-650 kgs + your lancia + everything else you want to carry. Also consider if u load the car up, the max towing weight is reduced proportionally as the max towing weights are based on car + driver + half a tank of fuel. The only car mfg I ever found that quoted towing weights with weight in the car are Subaru.
Your freedlander I think has a max of towing weight of 2t if I remember correctly. I recently drove an auto 150 m/jet Croma that had been used for towing, the gearbox was slipping under hard acceleration. Hope this helps.
