Approximately how many miles you have with this mod?
Did you noticed any differences in acceleration, consumption and engine running temp ?
Thank you.
Simple honest answer ZERO miles.
I fully researched and designed exactly what I was going to do ahead of when my EGR was to fail. Unfortunately it failed just before going on a 3000 mile round trip to Italy towing a caravan. I was thus forced to quicky buy a new EGR valve and I had already both swirl gaskets in stock.
But what my research and engineering logic tells me is this:
1) The EGR circuit indirectly measures air flow. It still gets this.
2) Cooler air intake via the EGR port increases charge density and thus will only have an improved effect on combustion. Seems stupid to me to have an intercooler only to feed raw hot exhaust gases (only slightly cooled via the water exchange cooler in the EGR circuit) back into the intake and thus increasing the temperature of the air from the intercooler.
3) No crappy soot being fed into the plenum chamber to clog it, the boost sensor and potentially gum up the swirl valves.
The engineering is sound IMHO but the implementation requires addressing these minor issues. I say minor as becuase they are but do require some fabrication to be done.
1) A new EGR inlet pipe need to be made OR the old one has to be cut and a tube attached.
2) Do you leave the existing EGR gas water cooler in situe or do you remove it and bypass the water flow? Part of the support for this coller comes from the pipe attachment to the EGR valve.
3) New filtered air feed. Take from main air box OR a separate cone small K&N / similar cone filter of the type you often get for dry sump lubricated engines. Critical point to not here is that the air feed MUST come from before the air flow meter otherwise the ECU algorith for calculating expected drop in main air flow due to EGR flow will be totally stuffed. Would be the same as just blanking off the EGR and we know that on the 16V Croma engine this throws a fault code/light a little way down the road.
My personal choice would probably be for a discrete cone filter as opposed to modifying the main air box. However the size of small cone filter may need increasing as the smaller ones may be more restrictive. Another disadvantage of a separate filter is that you now have TWO filters to tend to at service time.
Finally.... there is as always the dredded insurance question/notification where "has the car been modified?" is their catch all get out of liability question. On many policies "modified" is so open that putting fancy stripes/decals on your car or anything else (at their discretion) could be a serious issue.
With my current insurance company, and a few other companies I have tried they will not insure any cars with mods. All I was looking for was permision to do a DPF removal as for a Croma 2005 it is not an EU/UK legal requirement for EUROn or UK MOT.
The Fiat swirl / reducer gasket is NOT, and is easily a defensible and legitimate modification (or should I say change of part design) that any Fiat dealer could fit without telling you.
