tarquin1867
Member
Has anybody used the grooved type of discs on the Croma ? Are they worth the extra cash? As discs and pads have taken over from "you need a couple of brake pipes"on the MOT,( since the advent of stainless brake pipes), are they better?
In the dim and distant I have been able to reharden and skim discs (I worked as a metallurgist) but now they are so soft and the steel so low in alloys its impossible. This is why they are so cheap by the way so I am loathed to pay a load of money if they are not worth it and they wear down to minimum at the same rate . At present I am on the second set of pads on the original discs and the discs are at min 26mm and the car has only got 30000 on the clock!!
