When returned from having new springs, I had an ECU fault flagged, glowplug error, which shows about 20 seconds after startup, for about 30 seconds. The local garage (VW specialist) said he had reset the ecu, and reckons the ecu has a fault that requires sending to a specialist, I'm not convinced. I need to get a cable and link up the laptop, I have a copy of Yani's early free program.
If the ECU needs specialist work, I think I might ask Gus at Alfa Tune for an opinion, and if it needs his expertise would it be possible to remap for economy.
"It" is now in again having new front shockers, so the springs are off again, as one has an oil leak which may have been caused by the very sudden collapse of the front suspension.
