After driving home in the dark and seeing the miserable candle-glow on the road in front of me and the bright icy white area in front of most other cars, I've decided to have a complete headlight overhaul.
I'm replacing the full and dipped bulbs with high-performance equivalents, but was also going to change the sidelights for bluish ones to match.
The manual states (on p261) that there are "2 per light", but the fitting instructions on p267 don't mention anything about this. Looking into the lights from the outside, all I can see is the top of one bulb inside each light.
Is the "2 per light" thing a mistake, or are there two tucked away somehow?
One more question - does the Croma sense the current draw on these bulbs, so you'd get nagged if LED bulbs were used in their place? I know I may need resistors if I got these if that's the case. I'm not too sure about LEDs anyway - I got some in the past once and they were far too blue to be comfortable with.
