DoIDon'tI
Member
- Feb 17, 2008
- 470
- 81
My Croma 2.4JTD was recently suffering from the following symptoms:-
1. A 'Surging' sensation on medium acceleration
2. A 'cough' at about 1800RPM
3. Uneven running at 55-60MPH.
4. Uneven or 'lumpy' idle.
This all started after two tankfuls of supermarket diesel, might be unrelated but I'll not be taking the chance in future! I removed the nuts holding the coolant reservoir in place, moved it to one side and removed the two nuts holding the heatshield over the EGR valve. Disconnected the electrical plug and the two bolts holding the pipe on the bottom of the valve.
Removed the four mounting bolts and removed the valve. When the valve was off, I removed the six (I think?) torx bolts holding the electrical part of the valve to the mechanical part and all became clear - when the valve was manually operated it was sticking at the initial point of operation.
Used copious amounts of carburettor cleaner on the mechanical part of the valve and it cleaned up well; more importantly it was now smooth in operation throughout the range. Reassembled it all without incident and the car is now back to normal - all the above symptoms have gone. Total time taken was about ninety minutes.
When I did the above the car had done just over 31,000 miles, it has since covered another 2000 miles without any problems. I'm not guaranteeing this will fix all running problems but if your car has similar issues to the ones mine had then it might be worth a go - at £7 for carb cleaner it's not too much of a risk.
HTH.
HTH.
