im Axle Specialists
Thread Tools
Old 19-08-2008   #1
Belgium
Brake pads / disks wear issue
Just returned from the shop where all brake pads were replaced.
What bothers me is that pads from front right and left rear wheel were much more worn than the others. I belief that Croma has two independent brake sections and they apparently are crossed. Could be that one section brakes much stronger? When braking I don't feel any misbehaviour thus I'm bit confused what caused that difference in worn. Croma has passed tech inspection in April without any problems.
The worst was front right. The pads were completely worn and brake disc looked like 100 000km mileage according to the shop technician.
Front left shown 50% usage.
Unfortunately wear indicator wiring is on the left wheel so I was not noticed on time that pads are worn!
Croma Multijet 2005 120PS 48tkm (30 000 miles)
godol is offline Reply With Quote Quote
Old 20-08-2008   #2
Re: Brake pads / disks wear issue
Interesting my Croma was making a subtle grinding noise when I applied the brakes at first this was only noticeable in quiet cul de sac away from traffic. However after a year and again numerous trips to the dealer the noise became consistent and and was a lot nosier you couldn't fail to notice it. The dealer then said front disc had groove so both front discs replaced and pads at a cost of four hundred plus quid. When i drove off I noticed that the pads warning light was on this had never come on before yet the tech said my old pads were shot odd?. Anyway turns out they had fitted wrong pads so left the car with them new pads fitted with sensor warning light gone. However grinding noise still there left the car again phoned next day come collect the car noise still there refused to take car until fault sorted. Following day phone call car sorted problem back plate was catching, great I thought why couldn't you of resolved issue sooner. Two months on I have the same problem and brakes seem to collapse when applied, I personally think these cars are just a bag of ****.
Tony the Tiger is offline Reply With Quote Quote
Old 20-08-2008   #3
That sounds more like the one half of the braking system is binding slightly and wearing excessively as a result.
Alex
Dr Zoidberg is offline Reply With Quote Quote
Old 31-08-2008   #4
Curse of the were-rabbit
Bunny's Avatar
Bunny has donated!
My wear indicator came on today, going to get Rob to have a look for me to see how bad or not the wear is on the brakes / pads.
If needed be, i'll ask FAST to change them for me when there do my oil change, etc.
Mine: Croma 150 Mjet. His: Marea weekend
Bunny is offline Reply With Quote Quote
Old 02-09-2008   #5
zombie nation
Hellcat's Avatar
Trader Rating: 3
Hellcat has donated!
Quote Originally Posted by Dr Zoidberg View Post
Not sure how the proportioning valve works on the Croma, perhaps there could be an inbalance there? Get it to an MOT place and have them check the brake balance once it's got new disks and pads on.
Drives: Fiat Multipla Eleganza , Owns: Alfa Romeo 159 2.4JTDm
Hellcat is offline Reply With Quote Quote
Old 02-09-2008   #6
I'm having ongoing issues with my discs/brakes, there appears to be something sticking, catching to be honest I'm sick of this car and spending money on it however I'm just about to spend more dosh on a full RAC inspection as until I sought the problems I can't get rid.
Old 05-10-2008   #7
zombie nation
Hellcat's Avatar
Trader Rating: 3
a sticking or catching noise that sounds like it's from the frobnt brakes could be the heatshield rubbing against the hub/disc.
Old 16-06-2015   #8
Slovenia
master cylinder
lfcboy is offline Reply With Quote Quote
Old 16-06-2015   #9
Moderator
Peter Pick-Up has donated!
Russia
The problem was 7 years ago....will be cured by now, don't you think...??
Peter Pick-Up is offline Reply With Quote Quote
Old 18-06-2015   #10
Slovenia
maybe somebody has the same problem now, and try to solve it by reading this forum ... don't you think ???
Old 18-06-2015   #11
Hi all I spoke to a very experienced mechanic at work and all considered he suggested that it has to do with the stability control software. If you read through this issue on the forum this goes back to when they were new, all the mechanical parts are used on other very numerous cars with no issue so it makes sense that this is something unique to the croma! .It might be worth contacting Fiat they may well know about this.
Telegraph is offline Reply With Quote Quote
Thread Tools
(G) Brake Pads and Disks MF-Racing Stilo 21 04-10-2007 18:24
(T) Racing brake pads and disks lukesseicento1990 Cinquecento / Seicento 4 28-08-2007 18:34
(T) brake disks an pads chan Bravo / Brava 4 05-04-2006 13:59
(T) My brake disks and pads, pics inside melliottuk Punto (Mk2/2b) 1 07-09-2005 02:28
(T) FRONT DISKS AND BRAKE PADS slyman Punto (Mk2/2b) 1 12-07-2004 18:03
