Vectrolosys
- Jul 6, 2007
- 26
- 9
Hello,
A friend of mine has a 2006 (56 plate) Alfa Romeo 159 2.4 JTDm, I've placed this post in this forum as I want to see if any owners of 2.4 litre JTD equipped Fiats have had similar issues.
When travelling along the motorway, at 70mph in 6th, with cruise engaged, he began to lose power, to the point that he had to pull over and call the AA.
The AA operative arrived, reset the ECU and allowed him to continue, so he started to drive to the nearest Alfa Dealer. On the journey to the dealer, his top speed was limited to 50MPH, as the car had gone into 'limp home mode'.
On arriving at the dealer, they took the car and started to take various bits apart. He was advised that the inlet manifold had been destroyed and had taken the engine with it, which, though possible, I find hard to believe.
The car has only done 29,000 miles incidently. Alfa are making noises that he may have to foot the total cost for the new engine, something to do with the first two years being a manufacturer warranty and the third year being with a third party. The car is around 2.5 years old.
My question is this.
1 - Have any other 2.4 JTD owners experienced this issue?
2 - Is this issue the same one that the 1.9JTD can experience?
Having done some reading, this issue has similar 'Limp Home' symptoms and is due to a failing or failed EGR valve, which, can be cleaned but ultimately requires replacement of the inlet manifold.
3 - If the garage were to commence charging him for the work, what would be the first steps into taking the case further?
Many thanks in advance,
James
James
