Old 22-11-2017   #1
Cinq sporting rough idle and misfire
Hi have any of you ever had a rough idle and misfire before ? I have had a look through the forum and replaced the coil packs plugs leads map sensor cleaned the throttle body checked the earths but the problem is still there what to try next ...? Thanks.
DIDCOTT is offline Reply With Quote Quote
Old 22-11-2017   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Cinq sporting rough idle and misfire
open the bonnet in the dark and look for a light show.
If nothing, compression test
D
Thanks DIDCOTT thanked for this post
Old 22-11-2017   #3
Thanks I will take a look this evening
Thanks rallycinq thanked for this post
Old 23-11-2017   #4
If your ignition electrics are all new (my guess was going to be "coils") then the only other thing it could be is "petrol".
Disconnect the fuel hose to the injector and stick it in a small container. Is there a healthy looking fuel flow when you crank the engine over (try this with a cold engine)?
If you're not getting much flow, you may have to pull out the fuel pump and see what's up with it.
The beast ought to have a fuel filter somewhere too (possibly in the tank). When did you last clean/change it?
It might also be worth taking out the injector and having a look to see if there's any obvious blockage/dirt on it. They're tricky to clean off the car (you need a rig) but a squirt of carb cleaner might help it.
Ralf S.
No bullets for chaingun
Ralf S. is online now Reply With Quote Quote
Old 23-11-2017   #5
Thanks Ralf for taking the time to give a detailed reply I will carry out these checks and report back over the next few days.
Old 23-11-2017   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
How was the spark search last night?
D
Likes DIDCOTT liked this post
Old 23-11-2017   #7
Thanks for asking rallycinq.
I ran the car for 5 mins and looked all around the plugs leads and coils for blue flashes but nothing Iím hoping to carry out ralfs suggestions and also do a compression test as you suggested this weekend. I will update this with the results.
Likes rallycinq liked this post
(T) Rough idle and rich running Turbo Cinq 1242 Alex22 Cinquecento / Seicento 6 21-04-2010 21:58
(T) New Panda rough idle and occasional misfire tomlee Panda 9 25-06-2009 09:52
(T) Desired Idle revs, rough idle, slack throttle cable? ronnieronson Cinquecento / Seicento 13 15-09-2007 10:18
(T) Rough running cinq sporting kikuko Cinquecento / Seicento 3 07-06-2005 16:54
(T) Rough Idle on 899cc Cinq arseofbox Cinquecento / Seicento 21 07-10-2003 20:11
