Old 18-10-2003   #1
rate my sound system
Hi just wanted to know what you think ov my planned sound system??? feel free to give advice... coz i aint got a clue about sound systems, if the amps are right etc???? lol anyway im gettin it all from ere: http://www.ultimate-sounds.com/maaudio
6x9 to go on the rear parcel shelf:
http://www.ultimate-sounds.com/maaudio/100.htm
amp to power them:
http://www.ultimate-sounds.com/maaudio/hk797.htm
sub hopefully make my own box for it:
http://www.ultimate-sounds.com/maaudio/65.htm
amp to power it:
http://www.ultimate-sounds.com/maaudio/hk1997.htm
power cap:
http://www.ultimate-sounds.com/maaudio/86.htm
already have a kenwood head unit so is there anything else i need??? will it sound any good? any advice is welcome ;)
cheers
PAUL
AfterDark_Raver is offline Reply With Quote Quote
Old 18-10-2003   #2
oh n the price (converted from $) is 640 is that a good price for what ill be getting [?][?][?]
Old 18-10-2003   #3
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
you'll get the alternatives cheaper at http://www.mcs-direct.co.uk but i like what your planning! Just leave the 6x9's out of the equation cos they dont go well with a sub. Stick some Mid-Range speakers in the rear side panels and you should have a kickin system!
Hedge Seeking Missile
MrDerv is offline Reply With Quote Quote
Old 20-10-2003   #4
cheers brickfoot been lookin for somewhere in the uk to get the stuff :I
when ive saved me pennies up n got all the stuff ill post some pics 4 u all to see :D until then catch ya l8r
Old 20-10-2003   #5
MrDerv's Avatar
MrDerv has donated!
give you a hand fitting it if you fancy it? i'm a dab hand with wiring! and i'm local!
Wanted: Exhaust for my Cinq Sporting! PM me!
Old 20-10-2003   #6
Are you planning on pumping 1200WRMS through a sub rated at 600WRMS?
see: http://www.rockfordfosgate.com/rftech/wiringwizard/index.asp?WoofQty=1+woofer&WoofImp=Dual+Voice+Coil +-+4+ohms+x+2&image.x=12&image.y=9
Probably best to get a 2ohm stable amp that will put out about 600 - 800 WRMS max to run the sub(cheaper too!). Its always better to run a sub with an amp that is a little bit more powerful, so that the amp is in control, but 1200WRMS through a 600WRMS sub would cook the voice coils as soon as you whacked it up!
Not taking the mick or anything but who are MA Audio? Wouldnt it be better to save for longer and be happy with the best that make do with what you can afford at the time? Have a look at www.Caraudiodirect.com for some quality car audio
Cinquecento Sporting -- not broom yellow
Sando is offline Reply With Quote Quote
Old 20-10-2003   #7
P.S I agree about the 6x9's, leave them out. Use the money saved to get some quality components up front. Leave the rears out if you can, it will always sound beter.
P.P.S The cap is a waste of time. They are a fad. Totally useless.
Old 21-10-2003   #8
sando is talking sense, listen to the wise words...
mackett is offline Reply With Quote Quote
Old 21-10-2003   #9
100 watt 6X9s there a fing of the past! get some 600 or 800 watt ones! theyl liven the back up! as for the amp! you SHOULD run and amp approx half the maximum subs handling! if you wana loud install-ive recently installed a 10" 1100watt sony xplod penatgon sytle sub-it really kicks would recommend to any1! good luck
whos ur daddy!???
iandaman is offline Reply With Quote Quote
Old 21-10-2003   #10
I beg to differ. First of all, the 'maximum' watt rating isnt an accurate rating of a sub. You should always use RMS (root mean square)rating, this is an average power rating, meaning, you could run it with this much power all day long if you want. Secondly, an amp that is running a sub should always have an RMS rating slightly higher than the subs RMS rating to ensure that the sub is running at it's full efficency. Thats a fact. Try having a look on www.talkaudio.com for some real advice, all the top SQ and Sound Off guys go on there, they all run their subs at way, way over the RMS rating. I know they only use the subs for burps but the same principle applies in normal car audio.
I've said it before and I'll say it again: Ditch the 6x9's and spend the money saved on some decent components for the front.
800watt 6x9's??? seriously, is that RMS or 'peak power'. If its, peak power, you need to divide the figure by 4 to get an accurate rating!!
Old 21-10-2003   #11
this is going to make me sound like an arse kisser, but sando is spot on again!
Old 21-10-2003   #12
consider my ass kissed. ;)
Im not a pro or anything when it comes to car audio but I know a little bit. Just what I've picked up from friends or on Talk Audio.
Old 22-10-2003   #13
lol cheers for the advice and offer for the fitting, shame im just starting to save :( but as soon as ive got everythin ill take u up on that offer thanx a lot mate.... been thinking of taking the back seats out n making a 1 off install but i think that would cost a bit 2 much lol... i think i will ditch the 6x9's what should i go for instead?? oh n i think ill get this sub instead!!!
http://www.ultimate-sounds.com/maaudio/150.htm
gimme an opinion ;) only costs 360!!!!!
Old 22-10-2003   #14
MrDerv's Avatar
MrDerv has donated!
<blockquote id="quote">[size=1] face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by AfterDark_Raver
lol cheers for the advice and offer for the fitting, shame im just starting to save :( but as soon as ive got everythin ill take u up on that offer thanx a lot mate.... <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
No worries! just email me as soon as you're ready and we'll be able to sort it all in a day!
Old 22-10-2003   #15
That sub is more like it! 5000WRMS!!! lol! I would love to see that shake a cinq to bits! But for the money, there are a lot of better subs out there. Have a look at www.caraudiodirect.com if your planning on spending that amount of money look at the RE SE12 which is a lot cheaper and is the 'sub of the moment'!
Before you get a sub and amp, its an idea to look at that Rockford Fosgate site on the link above to see how best to wire it up, it can get very confusing when using duel voice coils.
Cinq Sound system DJ_Bucho I.C.E 59 17-05-2007 19:52
(S) What sound system? Dj REsound Cinquecento / Seicento 15 26-07-2004 15:53
punto hgt sound system ? damoboy I.C.E 0 23-07-2004 22:28
(T) Sound system error barnesm6 Bravo / Brava 2 21-02-2004 02:17
(G) Sound system janevj Stilo 4 16-01-2004 18:50
