CinqoSX
My cinq has been very noisy the past wee while, and I think I know what is wrong.. correct me if I'm wrong..
The exhaust sounds very loud and rattley when sitting still or going into reverse, as soon as theres some bite in first the noise goes away. Either this is caused by my front pipe or manifold, and possibly a buggered rear engine mount as I'm getting some noise from the gear box in low revs in the lower gears.
And also my engine is leaking oil, so I'm going to get the rocker gasket cover and sump cover replaced while I'm at it.
Could there be anything else I've not noticed that could be causing either of these problems? Someone told me to check the driveshaft seal too :bang:
Don't want to get it wrong as its going to drain the last of my wages for parts, just lucky the guy fitting them is cheap!
