Hi everyone
I need your advice on what to do with my poorly cinq!
I recently had the head gasket changed at 71000 due to it blowing on on of the water channels. Had the head skimmed new bolts and oem gasket fitted all fine again, also replaced the radiator. All fine again
Im now at 74000ish and the gasket has gone again on a different cylinder but this time im losing compression through the oil!
Now im coming up to 1 year since passing my test and have always looked at upgrading the engine size. Maybe 1.1 1242 or dare i say 1348!
My options at the moment are replace the gasket again and hope it will last this time as i am happy with the 899 (great engine)
Orrrr put and bigger engine in. I am very tempted to do this at the moment. I understand it will cost a bit of money as i will need additional stuff like engine mounts etc.
The only thing that would put me off that is insurance. I just did a test quote on gocompare stating larger engine replacement and the result came back cheaper than what im paying now :S :S
What do you guys think? what experiences have you had? Your advice will really help make my mind up
Thanks in advance
Chris
Thanks in advance
Chris
