Hi all,
I have a problem with a fiat seicento that belongs to my sister. The heated rear screen does not work (fuses and all connections to the rear screen are OK). The light illuminates on the button when it's pressed and goes off by itself after a short while but the screen does not heat up. Can anyone give me any suggestions?
Also, the front screen wipers are now faulty. They only work on the fastest setting and do not return to the bottom of the screen when you switch it off.
Thanks for your help in advance
