Thread Tools
Old 18-01-2005   #1
Engine identification help please
I have found a couple of 8 valve Punto engines in a local breakers but the guy there does not know if they are 1100 or 1242 is there an easy well to tell.
97 Cinq Sporting in Imola Blue with red leather interior. Full Abath body kit. Droped 40mm all round. OMP Strut brace, Red Dot Discs & Pads. 38mm Flowed Throttle Body, Mckcrich Chip & GSR Induction Kit.
mark_b is offline Reply With Quote Quote
Old 18-01-2005   #2
Funny saying here
jamie86's Avatar
Trader Rating: 1
jamie86 has donated!
Re: Engine identification help please
On mine 1.2 was stamped on the block......
Quote Originally Posted by A wise person
Mini invented the giant killer, VW started the genre, Ford & Vauxhall Desecrated it, but the Peugeot 205 GTi was undoubtedly the king of the breed.
jamie86 is offline Reply With Quote Quote
Old 18-01-2005   #3
where abouts?
Old 18-01-2005   #4
arc
this is where i stand
arc has donated!
Quote Quote:
So it's the Punto 60 engine then?
For the easy swap, yes. Look for the engine codes which are dot stamped on the top of the water pump housing. You may need some emery cloth or similar to clean the face up in order to read them - you're looking at the flat horizontal piece on the left front of the engine (looking from the exhaust side) just above the water tube, next to the cam belt cover.
Engine ID codes:
Punto 60, up to 1997: 176.B1.000
Punto 60, from 1997 : 176.B4.000
Punto 75, all years : 176.A8.000
Punto 55 1108cc engine up to 1997: 176.A6.000
Punto 55 from 1997 / all Cento 1108 SPI: 176.B2.000
https://www.fiatforum.com/cinquecento-seicento/22060-engine-swaps.html
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Thread Tools
(G) Uno Engine Swaps Chas Uno Uno 53 30-08-2017 21:57
(T) Problem.....RED Engine LED always on..... :( tubi Punto (Mk2/2b) 7 28-02-2006 13:48
(T) engine swaps HP Cinquecento / Seicento 0 31-12-2004 01:17
(G) What is my engine and gearbox worth... (Tuned 1242 8V - 6 Speed) puntoruss Cinquecento / Seicento 22 03-10-2004 19:47
