Thread Tools
Old 18-07-2008   #1
Seicento coolant sender connection at dashboard
Can anybody tell me where the line from the coolant temperature switch goes into the dashboard clocks pod on my Sporting SPI?
Under the bonnet its a green/white line but I don't see that colour on the edge connectors at the rear of the clocks. I CAN bell it out,but I just wondered if anybody knew straight off which line/colour it is at the connectors...
jimp is offline Reply With Quote Quote
Old 18-07-2008   #2
arc
this is where i stand
arc has donated!
Re: Seicento coolant sender connection at dashboard
do you mean switch for the radiator fan, or the switch that throws the "oh $hit" overheat line on on the dashboard?
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 18-07-2008   #3
It's for the "oh sh*t" light.
The radiator fan won't go up there, only to the fuse box I would think. I was expecting to see a green/white going in on an edge connector but the only thing vaguely near that is a pale green.
Old 19-07-2008   #4
Trader Rating: 5
fingers99 has donated!
What are you trying to do?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 25-07-2008   #5
sorry- I've only just realised you had responded to this thread!
I was trying to utilise the existing wiring from the Temp switch and tap it for the gauge I was fitting instead- but I just ran a new line after all...
Thread Tools
(T) Seicento Coolant Antifreeze Change Punto TDSX Cinquecento / Seicento 1 13-10-2007 15:21
(T) Seicento Coolant bassy-alex Cinquecento / Seicento 1 20-10-2006 23:17
(T) Seicento - Boiling Coolant barrymckenzie73 Cinquecento / Seicento 5 08-09-2006 12:04
(S) Seicento S - Dashboard Controls jhumpy Cinquecento / Seicento 3 11-04-2006 17:45
